I've been told that the easiest way to re-plumb my home (slab foundation) is to run PCV plumbing in the overhead. This may be the easiest, but is this the best solution? If given the choice between PCV in over- head vs copper under slab, which would you reccommend? What are drawbacks or advantages to either method? Thanks in advance for any advice you could offer.....
