: I have a toilet in my trailer home that will not flush all of its contents completely. We have plunged and tried liquid drainos. It has also been snaked and still no help.. any suggestions would be appreciated. Tim Tim, You may have a build up of lime and calcium in the flush holes under the rim of the stool. Also there is (sometimes) a hole about the size of a quarter in the bottom that gets plugged. Use muratic acid to disolve the build up. Call a master plumber to get you started.Do not try it by yourself if you are not formiliar with acids.Dale Peck LMP Also a coat hanger will get a lot of it out.
