| Posted by Steve Nadler on July 10, 1999 at 20:39:32: | |
It sounds like you have an 09 series single handle tub/shower. The faucet uses our older Avante cartridge (s74-292). After about 4-5 years of use the cartridge can become stiff and may need replacing. However, if you used WD-40 or any type oil it will temporaily improve but soon become almost impossible to use. In the future, I recommend you only use silicon based plumbers grease on this (or any) faucet. Oil based lubricants can cause the rubber washers/o-rings to bloat and this will make the operation very difficult. If you email me your name and address I will be happy to send you out a new cartridge along with a small tube of the recommended silicon grease. Look forward to hearing from you. Steve Nadler |
