Low Flush Toilets
Posted by Alan Hirst on July 09, 1999 at 21:43:37:
I have just discovered you web page. This is after installing 2 Kohler Wellworth toilets K-3423.
I have found that these really work well. I was sceptical but they do the job. Pardon the pun.
I did have what I thought was a faulty flapper on one. Kohler immediately sent me a replacement
flapper but this was not the problem as the new flapper valve didn't fix it.
On pulling the tank, I discovered that both the large tank washer and the 3 hole gasket were scored
where they mated the tank.(factory assembled)
Either or both of these may have been the cause. A slight smear of silicone on the seating areas
(let set) and reassembly solved the problem. I have advise Kohler of this.
For the price these can't be beat. Also with a $60.00 rebate from the water district they are just about
Replies to this post
