Re: Checking Water Pressure
Posted by Terry Love on July 09, 1999 at 19:15:31:
In response to Re: Checking Water Pressure
 : Terry - I need to check my water pressure and I'm not sure : if this is something I can do myself or if I need to call : a plumber. The association where I live has told me : my pressure is 90 PSI but I'd like to check this myself : and if so I'd like to fix it oppossed to spending the : $200 the association has quoted. : Can you give me any hints on how I go about checking : the water pressure and then fixing myself. : Thanks Miai, Using a water pressure test gauge on an outside faucet will show you the pressure. If you have a pressure reducer on your water system, it may need adjustment. If not, one may need to be added. Terry
Replies to this post
There are none. |
