| Posted by Terry Love on May 24, 1998 at 11:45:06: | |
| In response to Re: excessive water in sump | |
![]() Bridget, I encourage home owners with sumps, to if at all possible, create a gravity drain from the problem to a working drain, be it the City storm or even down to the street below. Using a good quality pipe such as ABS or thick PVC and plumbing fittings will allow the use of a snaking machine if there are problems with the line later. With homes I have built, I was able to intercept the water before it entered the dwelling, with the use of pea gravel and perf pipe or with a gravity drain from inside the footings. No pumps were used. Regards, |
| There are none. |
