Re: new basement shower drain connection
Posted by Terry Love on May 19, 1998 at 01:10:07:
In response to Re: new basement shower drain connection
 Paul, Yes, this is a difficult job. After doing hundred of these installations, I would not be comfortable having even an apprentice do the installation. Locating the center for the p-trap comes first. (it has to have a p-trap) Set the p-trap in place without the riser portion. Install the drain fitting on the enclosure and then set the enclosure in place to get the measurement between the trap and drain. Pull the enclosure out, glue in the riser portion, and reinstall the enclosure. (the handle of a hammer works well to guide the pipe into the drain fitting. Good Luck Terry Love
Replies to this post
There are none. |
