| Posted by joe on June 18, 1999 at 19:43:39: | |
| In response to Re: Toilet: Must hold down handle.... | |
: Our bathroom toilet will not flush without the handle being held down until the flush is complete (ie. not automatic). Once the handle is released, it fills as any normal toilet will. : Does this little problem require new hardware be installed, or does it simply require an adjustment in the existing hardware? : Thank you in advance for your help. You may want to take some of the slack out of the chain that attaches to the handle, if thats not the problem and the handle itself hasn't moved because of a loose nut which is rare someone else will have to give you advice, joe |
| There are none. |
