Re: Water Pressure
Posted by Terry Love on May 18, 1998 at 21:38:07:
In response to Re: Water Pressure
TO READJUST reduced Pressures, loosen check nut and turn adjusting screw counter clockwise to raise reduced pressure and counter clockwise to lower reduced pressure
Pressure regulators should be cleaned every six months according to Watts. Rebuild kits are also availible. ( They should last longer than seven years Allan, try the adjustment first.
80 PSI it the max the water pressure should be.
Replies to this post
There are none.
