| Posted by Terry Love on June 12, 1999 at 21:10:25: | |
| In response to Re: 2 ??s: Wonderboard and toilet flange | |
![]() Q1: I've received multiple, conflicting reports... Some say put wonderboard over greenboard and others say you can attach the wonderboard directly to the studs. Which is it??? Which is preferred? Staple a vapor barrier over the wood stud, leaving space between studs for ventilation and then attach the wonderboard to the studs. ( If you put bisqueen around the enclosure, and then cut out between the studs, this would prevent the wonderboard from getting the wood wet, and the openings between the studs would allow the back of the wonderboard to dry) I would add more thickness to the floor before you lay the vinyl. If you look underneath the toilet, you will note that there is room for the flange to set higher than the finished floor. Not much, but some. |
| There are none. |
