Offset toilet flange with oblong shaped opening
Posted by John Ruebke on June 11, 1999 at 16:00:02:
My toilet flange in the second floor bath has an offset flange that is oblong and with an opening larger than the size of a wax ring. I also had to added a new ring with slotted holes for the closet bolts. This has caused the toilet to rock and I can not maintain a seal. Local plumber suggests cutting a hole in the ceiling in the room below the toilet to install a new flange. Do you know of some other options that I should try first? I really do not want to have to replace the ceiling below.
Replies to this post
There are none. |
