Re: Clogged main drain line
Posted by Bud...Suncoast Plumbing on May 17, 1998 at 08:19:10:
In response to Re: Clogged main drain line
Ed: Short of hiring a plumber for the job,(and that's not a guarantee that the problem will be solved), you may wish to rent a small motorized snake that has a 3/8" cable and a drop head grease cutter head attatchement. The key to success is" go slowly and cautiously", if you get the snake stuck in the drain, you have lost ground. Lots of luck...Bud
Replies to this post
There are none.
