| Posted by PBM on May 15, 1998 at 10:56:36: | |
My husband & I just bought a 15-year-old house. The tub has a single handle tub/shower with the diverter directly below the handle. The tub handle was grimy and I wanted to replace it. Simple, right? Wrong. When we removed the little plastic cap, the handle screw was stripped. So we cut the main water supply off and removed the whole assembly. I do not know the proper terminology for all the parts so I hope you understand what I am about to ask. We replaced the ball, the cam/packing and the knob. When we lined up the cam/packing with the notch in the pipe, the handle was no longer vertically positioned. It worked fine (hot, cold, no leaks, etc.), you just have to move the knob from left to right to turn off, up for hot and down for cold. So first of all, I would like to know if we somehow inadvertently repositioned the actual pipe that the water supply comes through (the one with 3 openings). Secondly, when we tried to push the diverter in, water came of the shower head, but water also came Any suggestions would be greatly appreciated. Thanks, |
| There are none. |
