I am helping a widow fix leaky, rusty HARCRAFT lavatory "COBRA" faucets*. Where can I obtain the threaded, notched galvanized steel lock washers that clamp the faucet valve body to the counter top ( the washers have an inside hole diameter of 7/8-inch and 20 threads to the inch)? An alternate clamping method is to use a large washer and a nut that has an inside hole diameter of 7/8-inch and 20 threads to the inch. Where can I obtain such a nut ?? ANY other Suggestions ?? The Chrome inserts to the Lucite faucet handle have corroded badly and no longer grip the faucet stems. Where can I get chrome inserts or complete 2-part Lucite & chrome handles ? The faucets are connected to "Tee" brass fitting with plastic, braided flex tubing that have sharp "S" bends and are about 20 years old. The fittings on the flex tubing and Tee appear to be female 3/8-inch flair fittings. I would like to replace these with steel braided flex tubing, but the plumbing supply shops don't have such a replacement tubing with flair fittings. Is there a simple method to assemble or obtain a conversion fitting that converts the 3/8-inch male flair fitting to a 3/8-inch compression fitting so I can use the standard 8-inch or 12-inch steel braided flex tubing ?? Or do you know of another method or source to connect the faucets to the spout with more durable material than plastic braided tubing ?? * THE HARCRAFT FAUCET EXPLODED VIEW APPEARS ON P & M (PERFECT MATCH), 1994 PLUMBMASTER CATALOG, PG 1-345.
Thank you, Jerry Arnold garnold@svl.ems.lmco.com (408) 743-1221 (408) 756-4252 (FAX)
