| Posted by Bill Mellon on May 23, 1999 at 03:30:22: | |
I'm putting a Jacuzzi in an alcove. They say it should supported underneath with a bed of mortar or plaster covered with 2 mil poly. I checked old messages here & they don't quite lay out the details as much as I'd like... 1) Exactly what kind of mortar and plaster? 2) Which is preferable, and why? 3) Is plaster water-proof, or will I have a big mess if there's a leak? 4) Can the material be removed easily later? 5) IMPORTANT - Do I just mound it up underneath & plop the tub on top? Won't it squish/flow out from underneath? Should I build a frame around the area to hold the material in? This is a sensitive issue for us since our current tub cracked in the middle from improper support/ One other question - should I put some kind of insulation between the tub & alcove walls to cut |
