Re: Installing Toilet in Basement.
Posted by hj on May 20, 1999 at 23:39:31:
In response to Re: Installing Toilet in Basement.
The regular flanges go on the outside of the pipe. If you are installing it to the inside, then you are probably using a 3" flange into a 4" pipe. Your success will be determined by how far the 4" pipe size extends into the floor. You may have to cut the end off the flange.
: I am trying to install a toilet in my basement. The
: drain pipe was intsalled in the concreat floor.
: I can not get the floor flange to go into the pipe. It
: goes in about 1/3 of the way and wont go any further.
: It seems as though the drain pipe is not round. I have
: tried to smooth obvious bumps that I can see in the
: drain pipe, but the flange still will not go in.
: What can I use, or how can I get these parts to fit
: to gether?
: Thanks for the help.
: Getting Frustrated
Replies to this post
There are none.
