Re: HELP.....I SMELL GAS.....
Posted by Dale's Plumbing Service on May 16, 1999 at 09:37:10:
In response to Re: HELP.....I SMELL GAS.....
: I keep smelling this gas smell. I had the furnace checked, and they cleaned it out and said it was fine. Could it be the hot water heater? It's about 15 years old or so, and on occasions, we have found water around it on the floor. It also has these yellow-ish brown streaks running down the sides. Could the gas smell be coming from that, or not? Do the streaks, or water on the floor indicate that it's getting ready to quit on us? Please help!!!
Tammi, you need to call a licenced plumber and have him put a gas test on your home. If no leaks are found have him check the flue.If your water heater is leaking replace it. Dale
Replies to this post
There are none.
