| Posted by hj on May 15, 1999 at 11:02:06: | |
| In response to Re: Sewage Ejection & Wash Machine | |
The impractical side of discharging into the overhead line is that in the event of a septic tank backup, that washing machine connection will allow ALL the sewage to overflow into the basement area. Not a pleasant situation. Millions of washing machines drain into sump and ejector pump basins without any detriment to the pump. : I am in the process of putting a bathroom in my basement. I am : 1) Is it true that a washing machine pump is capable of pumping 8-10 vertical : 2) If #1 is true, am I better off, just pumping into a line that can be gravity : OK - three parts....Part of the reason I have been told to do option 2 is that : Thanks for any help you can give. : P.S. I am planning on buying a little giant sewage ejector pump.
| There are none. |
