Re: Water to refrigerator
Posted by Steve on May 12, 1999 at 16:57:57:
In response to Re: Water to refrigerator
Two additions: The refrigerator doesn't always have a quarter inch compression fitting for attaching the ice maker line. Some have garden hose fittings, so check this out beforehand. Kits are available at most home centers and at Sears.
: The refrigerator has a 1/4" compression coupling on the back for a copper. Depending on the position of the refrigerator related to the closest cold water source, you'll perhaps need to drill a cabinet to get to the sink, a wall to get to another source, or have another supply line run. Self piercing taps (a valve with a sharp point that punches into an existing copper line) are available that you can "saddle" onto a line under your sink (or wherever) to provide a source.
: However you route your line to the water source, when figuring how much copper tubing you need, be sure to allow for a loop about 2' diameter behind the refrigerator to give you plenty of slack to pull it out for cleaning & servicing.
: Hope this helps - Jim
Replies to this post
There are none.
