Fiberglass shower drain installation
Posted by Austin on May 12, 1999 at 00:10:46:
I'm putting in a new fiberglass shower. The drain assembly is brass and has a rubber ring that is compressed with a large notched brass ring to seal the drain to the 2" PVC drain stem. Should the rubber ring be coated inside and out with plumber's grease to give the ring a better seal. One plumber friend says "No" and the supplier says "yes". What has your experience shown? Thanks for your comments....Cool and sunny here at the New Jersey shore.....Austin
