| Posted by Bud...Suncoast Plumbing Inc. on May 09, 1999 at 21:26:39: | |
| In response to Re: Slow bathroom drain | |
Big Al: Get a good strong "Wet-Vac", and place the hose right over the drain in the bottom of the Lav. Plug up the overflow with a wet rag, and fire up the Vac. Take the Vac outside and examine the contents in the bottom...you may find that 14" pipe wrench you left in the line when you were working on it last time. Lots of luck ..Bud |
| There are none. |
