| Posted by Dale's Plumbing Service on May 06, 1999 at 23:09:53: | |
| In response to Re: Broken Toilet Flange Metal Ring | |
: The Metal ring on my pvc toilet flange is broken. : I would like to replace the whole piece. : Is there a recommended method for removing the old : pvc flange from the 4" pipe? I was planning to care- : fully cut and chisel it out; however, I am open to more : experanced advice. David, there are repair kits that you can use and save you all that work. or if it is a 4" pvc flange you can use an inside cutter on a drill and cut down 1 1/2" and then glue a 3" hub flange inside the 4".just a suggestion. Dale |
| There are none. |
