Re: Adjusting Pressure Reducing Valve
Posted by hj on May 06, 1999 at 16:27:58:
In response to Re: Adjusting Pressure Reducing Valve
At 60 psi, I would remove it entirely. : I have a Watts Regulator Model 25AUB pressure reducing valve (stated range is 25 - 75 lbs) just after the main input valve into my house. : It has a screw adjustment with a locking nut. The city has stated the water pressure in the main on our street is 60 lbs, : but when I recently turned on sprinkler system, there is not enough pressure to reverse the impact sprinkler : heads. I have taken the heads of the system and flushed the line, to no avail. How do I adjust this valve to increase pressure : (screw in or out?) without increasing too much to blow the pressure valve on my hot water heater?
Replies to this post
There are none. |
