Re: Moen Single Lever Shower Faucet Dripping
Posted by Lou on May 05, 1999 at 12:20:19:
In response to Re: Moen Single Lever Shower Faucet Dripping
Turn off the water feeding the shower valve. Remove shower valve handle, then remove the clip that holds cartridge in valve body. Grab the valve stem and pull out old cartridge, sometimes they are a little tough to get out and you will need a Moen cartridge puller. Grease up new cartridge with Moen silicone based grease, if you use normal grease it will cause the rubber to swell, therefore making it harder to change next time. Replace handle and turn on water...Lou
Replies to this post
There are none. |
