| Posted by Dale's plumbing service on May 04, 1999 at 18:16:42: | |
| In response to Re: Low Water Pressure in Bathtub | |
: : My water pressure is so low in the : : bathtub that it takes 20 minutes : : to fill the tub. A couple of : : plumbers have told me that it's : : just the way the water is piped : : in or something. However, the : : pressure is fine when I use : : the shower, and the bathroom : : and kitchen faucets have good : : pressure, too. Would replacing : : the shower set-up help? I : : have a shower head, two : : hot and cold handles for : : the tub, and a plunger-type : : faucet to switch from tub to : : shower. I'm sure there is : : plumbing terminology for this : : combination, but I have no : : idea what that is. I wouldn't : : want to replace my fixtures : : if it wouldn't make any : : difference in the tub pressure, : : as it would require pulling : : out all my tiles to replace : : them with the newer style shower : : combinations. Thanks : vicki, the only thing i can think of to do is to take the spout off and change the rusted gavvanized nipples from the faucet to the spout. this may require you to do it from behind the tub if you have an excess panel or cut one,or do it from the front.make sure all the rust is cleaned out from the brass tub faucet. replace with brass nipples and elbow. Dale
| There are none. |
