Re: Proper Venting of Washer & Laundry Tub
Posted by Dale's plumbing Service on May 04, 1999 at 17:49:57:
In response to Re: Proper Venting of Washer & Laundry Tub
: I am in the process of remodeling my basement and have come across a problem with the plumbing of the washer and the laundry tub. I must relocate both of these to a position that is about 25 feet from the sewer lines/vent stack. Luckily there is an unused sump basin that I can dump the washer and laundry tub drains into. I plan to use a sump pump to eject the waste water into the sewer through a pipe running in the basement ceiling. My question is: does it mater if I dump the waste water into the main sewer stack or can I tap into one of waste lines coming from the first or second floor. This is easier since the main stack is cast iron while the other waste lines are PVC. Also, do I need to vent this since it is just washer water? If so, does it mater how I tap the vent line into the system in relation to the waste line or can I connect it to the most convienent point? Thanks in advance! ed, dumping the washer and laundry sink in the sump pit is an iffy,it will work but will your code allow it. you need to put a check valve on the sump discharge line. you will have to put some kind of cover over this hole to keep the odor out of the basement that will be there in a month or so. you need to tie into the cast iron with a 4x2 wye. so the best way is install a sewer lift can where the existing sump pump is as it will have a lid and also you need to vent it into an existing vent line or bring it out seperatly through the roof.you can use an 1-1/2" sump pump to pump this water out to the 4x2 wye.Dale
Replies to this post
There are none. |
