Re: Replacing toilet
Posted by Terry Love on April 24, 1999 at 12:39:23:
In response to Re: Replacing toilet
: I have an old toilet i want to replace. Is there
: a standard dimension that toilets are built for that I should
: be aware of when purchasing a new toilet to match the
: existing space ans size ?
: also I am thinking about a flushmate type toilet and would like
: to know what the minimum water presure should be in
: order for this to work. (we are on a well and sometimes
: our pressure drops below 40lbs ?
Joe,
Standard toilet rough-in, the distance from the back wall to the bolt centers, would be 12". The Gerber Ultraflush requires at least 11-3/4". Some of the Gravity tank toilets can use 11-1/4" to center because of the smaller tanks.
At least 20 PSI and no more than 80 PSI.
If your well system has sand in the water, I would consider one the the good gravity models.
The new 503 series Flushmate tanks are now made of resin would are less prone to rust outs and are quieter.
Replies to this post
There are none.
