| Posted by Terry Love on May 04, 1998 at 13:53:50: | |
| In response to Re: Burn injury | |
![]() : Three weeks ago my two children were burned while in the bathtub. The pressure had somehow built up behind the wall and blew off the hot water nozzle Paula, It could be that the top thermostat of the tank malfunctioned and didn't cut the power. Replacement of the top thermostat may be in order. Also check to see if the T&P device is installed on the tank. These are set to 210 degrees and 150 PSI. This should have let the excess pressure out of the tank. Terry |
| There are none. |
