Re: toilet flange replacement
Posted by Dale's Plumbing Service on April 18, 1999 at 16:26:46:
In response to Re: toilet flange replacement
: Need to replace a cracking pvc toilet flange. any advice on how to remove it without damaging the pipes or tile around it would be appreciated. Craig, there are repair kit for your flange problem. you could buy another floor flange with a metal ring and snap it off the pvc and lay it over your old pvc flange and screw it through the old flange into the floor, or check on a repair kit. they also make flanges that will slip down inside your 4" pvc pipe and lock in to the pvc. Dale
Replies to this post
There are none. |
