Re: low water pressure in kitchen
Posted by Dale's Plumbing Service on April 14, 1999 at 04:59:01:
In response to Re: low water pressure in kitchen
: I have low cold and hot water pressure in my kitchen faucet. it happened suddenly and has decreased gradually. it is not thea aerator and there are no visible leaks inside or outside. Please help! you need to take this faucet completly apart, flush both hot and cold lines,clean the dirverter if you have one, put plumbers grease on all moving parts (just a little)and see if this helps.make sure you have all the parts out of the areator,like the restrictor stuck up in the spout.Dale
Replies to this post
There are none. |
