| Posted by Frank on April 13, 1999 at 09:42:41: | |
| In response to Re: Installing a valve to the gas outlet | |
Oatey Great White is also a teflon-based compound that is readily available. : I want to obtain a gas dryer. There is a gas line already installed on the wall. It has a cap, not a valve. I believe that all I have to do is to remove the cap and install a hand valve instead. My question is what kind of sealing materials I should use? Would Teflon tape do the job or is there any special sealant for gas?
| There are none. |
