| Posted by Terry Love on April 12, 1999 at 13:31:51: | |
| In response to Re: How do I install Pre-cast Neo-angle shower on slab? | |
![]() : Thanks in advance. I have a basement stub out that appears to be set up for a bath. The toilet and sink drains are simple enough, but how do I do the shower. One option appears to be to build up a platform high enough for the drain to be installed. Otherwise would you tear out the slab, and if so, how do you deal with the problem of the fiberglass base flexing. I'm assuming the slab gets repoured. ( Yea , I know, never assume)This one has me stumped, any help will be welcomed. Thanks again, Gary : Gary, Many homeowners "do" build a platform. Plumbers "prefer" doing the job, the way it was meant to be done, by having the pipe work done below slab. An exception to this would be building up the "entire" floor of the bathroom and using something like a Quik Jon pumping system. Stepping out of a shower from eight inches up can't be good. And please, any homeowner that puts in a basement tub or shower, "do" use a p-trap on the drain. This board gets many questions from homeowners that don't like the idea of breaking concrete. A sledgehammer or concrete saw does a fine job. The finished job is professional and more usable in the future. Terry |
| There are none. |
