Re: How do I install Pre-cast Neo-angle shower on slab?
Posted by hj on April 11, 1999 at 23:49:06:
In response to Re: How do I install Pre-cast Neo-angle shower on slab?
One problem with trying to use the existing drain as is, is that it will be 1 1/2" and the shower needs a 2" one to drain properly.
: : Thanks in advance. I have a basement stub out that appears to be set up for a bath. The toilet and sink drains are simple enough, but how do I do the shower. One option appears to be to build up a platform high enough for the drain to be installed. Otherwise would you tear out the slab, and if so, how do you deal with the problem of the fiberglass base flexing. I'm assuming the slab gets repoured. ( Yea , I know, never assume)This one has me stumped, any help will be welcomed. Thanks again, Gary
Replies to this post
There are none.
