: I assume this is what I have after trying to recaulk the tile and sealing the caulk, I'm still getting leaks onto the floor at the bottom of the curb of my tile. The shower is in a corner, and it's leaking on all four sides into the walls of other rooms. The house is only 5 years old. Is this common? Is this something that should be covered under a home warranty? HELP!:!:! BJ, plug the shower drain and fill the shower pan to the top of the dam. let it set to make sure if this is what is leaking.put a cap on the shower arm and turn on the shower and check that pipe first.good luck. Dale
