Re: Basement ejection sump requirements
Posted by Dale's Plumbing Service on April 10, 1999 at 01:52:45:
In response to Re: Basement ejection sump requirements
: 1. The kitchen has a two inch vent thru the roof. Can I use a "Y" pipe and tap into this
: vent above where the sink is to avoid cutting another hole in the roof ?
: 2. The kitchen has a two inch drain line that runs for about 25 ft to the main line. Can I
: use a "Y" pipe to tap into this line for the injection pump or would it be better to run a seperate
: 3" line. The house is a walkout basement on a lake that has a washer, dishwasher, kitchen sink, and
: full bath dumping into the sump.
: Thanks
you can tie into the 2" vent on the kit sink useing a 2" san tee but if you are measuring the out side of the pipe it's only 1/1/2" pipe inside diameter.most kit sinks are vented with 1/1/2" pipe. the wye should be put in a 4" pipe but will work if you only have 3".if you have to follow your local code you better check with them.if not good luck in your project.Dale
Replies to this post
There are none.
