| Posted by hj on April 09, 1999 at 23:29:28: | |
| In response to Re: Basement ejection sump requirements | |
You can connect to the sink drain if you make the connection as far away from the sink as possible, but it would be better to install a new 2" drain pipe. The vent can tie in to any existing available 2" vent. : : 1. The kitchen has a two inch vent thru the roof. Can I use a "Y" pipe and tap into this : vent above where the sink is to avoid cutting another hole in the roof ? : 2. The kitchen has a two inch drain line that runs for about 25 ft to the main line. Can I : Thanks
| There are none. |
