| Posted by Kevin Nilles, Journeyman Plumber on April 04, 1999 at 19:27:34: | |
| In response to Re: TOILET TANK-SWEATING | |
: : HOW DO I STOP THE TANK FROM SWEATING--I HAVE A LARGE FAMILY AND THE TOILET GETS PLENTY OF USE-WHETHER IT IS THE COLD WATER INSIDE THE TANK OR THE CONSTANT USE --IT SWEATS AND GETS THE FLOOR WET WHAT WILL STOP THIS ? :You can use a tempering valve to mix a little hot water with the cold, your local plumbing contractor can probably fix you up with one. You could also buy an insulated tank (new toilet) or a toilet with one of the new slone flush valves in it. Kev |
| There are none. |
