| Posted by Kevin Nilles, Journeyman plumber on April 04, 1999 at 19:12:34: | |
| In response to Re: TOILET TANK-SWEATING | |
: : HOW DO I STOP THE TANK FROM SWEATING--I HAVE A LARGE FAMILY AND THE TOILET GETS PLENTY OF USE-WHETHER IT IS THE COLD WATER INSIDE THE TANK OR THE CONSTANT USE --IT SWEATS AND GETS THE FLOOR WET WHAT WILL STOP THIS ? : well you can use hot water instead of cold water, ha ha just kidding. put a toilet tank cover on the tank,thats all i can think of.Dale :Out here in the east some of the companies here can install a tempering valve to mix a little hot water with the cold to make it closer to room temp and help eliminate the sweating. You can also change toilets and put in an insulated tank or one with a slone flush valve to eliminate this problem. Kev |
| There are none. |
