| Posted by Dale's Plumbing Service on April 04, 1999 at 01:55:40: | |
| In response to Re: Bathtub overflow and drain | |
![]() : Bathroom was renovated. New cement board, tub, floor, you should be able to replace the waste and overflow from the back as long as you can get to the slip nut on the trap.you may be able to use a tool on the drain to unscrew it but a lot of times it has to be cut out with a hack saw or sawsall. better get a pro for this. you may be able to get new parts for the front to replace the old ones with out taking out the whole waste and over flow. Dale |
| There are none. |
