Re: Hot Water Heater
Posted by Dale's plumbing service on April 03, 1999 at 20:41:45:
In response to Re: Hot Water Heater
: I have noticed a large puddle coming out from under the hot water heater in my basement. I attempted to run hot water and found that I have none.
: What could be the problem ?
: Thanks
laurie, it sounds like the water heater went to water heater heaven. it's leaking and the water may have put the pilot out. check with the manufacture and see if it may be under warrenty. if it is 5 yrs or less it should be. Dale
Replies to this post
