| Posted by willy on April 02, 1999 at 01:38:19: | |
| In response to Re: underground copper pipe | |
: Solder joints are not allowed under a concrete slab inside a building. Underground or outside there is no problem with them. L is adequate. PVC should not be installed inside a building. : : I need to run a 1 inch cold water line from the crawl space : : Thanks, Mike when i do copper outside i silver solder the joints or you could use flared fittings. silver solder is much cheaper in cost and when done properly. will never leak. |
| There are none. |
