| Posted by Jeff on April 01, 1999 at 11:22:11: | |
| In response to Re: Wall Outlet Toilet | |
You're not kidding. American Standards swears that this is the way it's supposed to work. I hooked everything up last night and no leaks thus far. I used the sealant that came with the gasket. If I have problems, I'm going to Goop it. : The gasket had better seal to the flange if you do not want a leak. There is only one flange and you have the correct one : : I'm installing an American Standard Yorkville EL wall outlet toilet. I've got the neoprene gasket as
| There are none. |
