Wall Outlet Toilet
Posted by Jeff on March 30, 1999 at 10:30:05:
I'm installing an American Standard Yorkville EL wall outlet toilet. I've got the neoprene gasket as
recommended, but can't seem to figure out how this is going to work. The gasket goes on the toilet's
horn with no problem, but when you hold the gasket up against the closet flange on the wall you can see
that it's going to sit on the surface of the flange. My concern is that since there's a small depression(the
opening tapers down to pipe width) in the flange that the waste will collect in there. Is there a different
type of flange that doesn't have this depression(groove)?
Replies to this post
