| Posted by hj on March 27, 1999 at 19:56:22: | |
| In response to Re: Use Single 'Y' Flue Pipe for Venting Gas Boiler&H20 Heater | |
Compute the area of the two vents, add them together, and then use a sinle pipe that has at least that area. A 3" and a 4" would require a 5" vent, but (2) 4" ones would need a 6". and so on. : I will be remodeling my basement and am considering replacing the old (30-40 yrs) natural gas fired boiler for our hot water heat. To consolidate items for floor space, I'm making a single 'utility room' with a washer, dryer, 50 gal. natural gas water heater and natural gas fired boiler. However, this room has a chimney with only 1 flue in the chimney. Can both the gas water heater and boiler both be vented through this single flue by using a single 'Y' vent pipe connected to the single chimney flue? If so, what what minimum size vent pipe (4"? 5"? 6?" More?) should be used to ensure there's sufficient up draft so no exhaust gases are blown back down into the room?
| There are none. |
