Re: Use Single 'Y' Flue Pipe for Venting Gas Boiler&H20 Heater
Posted by dale's plumbing service on March 27, 1999 at 08:33:20:
In response to Re: Use Single 'Y' Flue Pipe for Venting Gas Boiler&H20 Heater
: I will be remodeling my basement and am considering replacing the old (30-40 yrs) natural gas fired boiler for our hot water heat. To consolidate items for floor space, I'm making a single 'utility room' with a washer, dryer, 50 gal. natural gas water heater and natural gas fired boiler. However, this room has a chimney with only 1 flue in the chimney. Can both the gas water heater and boiler both be vented through this single flue by using a single 'Y' vent pipe connected to the single chimney flue? If so, what what minimum size vent pipe (4"? 5"? 6?" More?) should be used to ensure there's sufficient up draft so no exhaust gases are blown back down into the room?
: THANK YOU!
: ken abrahamsen
ken , it will depend on the flue size of the boiler and the 50 gal water heater. some 50 gal have 3" and some have 4" flue sizes.i would think the both will total a mim of 6". give us the sizes of both.
Replies to this post
There are none.
