| Posted by dale's plumbing service on March 26, 1999 at 19:04:02: | |
| In response to Re: Can't get new tub in the bathroom ...... | |
: ...because the room width is exactly the width of the tub. : I can cut up the old tub, but how do I get the new one in ? : Is knocking out a wall the only solution ? you will have to take out the sheet rock on the end walls, if you have a tub only, stand the tub up and lay it down away from the faucet end. if it is the same length (5') it should go in, a little work but i have done it many a time with cast iron tubs and by my self. good luck. |
| There are none. |
