| Posted by Paul on March 24, 1999 at 21:13:01: | |
I have recently experienced problems with a toilet located on the 2nd floor of my (2) story home. When you attempt to flush this toilet there is not a good strong flush noise as the water level lowers in the bowl. In fact the water begins to swirl but stops about halfway through the flush cycle. The other (2) toilets in my home (on the 1st floor) flush well. I removed the toilet ran a 30' snake down the drain but did not hit any obstructions - I also ran the snake through the toilet no obstructions. I installed a new wax ring and reinstalled the toilet - the problem is still occuring... At the present there is a need to double flush the toilet to remove all waste. Any ideas??? Thanks, Paul |
