| Posted by dale's plumbing service on March 19, 1999 at 22:17:11: | |
| In response to Re: creaking pipes | |
: Pipes make a noise in both bathrooms every now and then?? pipes? hot water pipes? drain line for lav? whaterver pipes they are they are expanding when hot water goes through them. loosen them up if you can still see them from the basement,there may be a strap to tight. if it's in the wall well you may have to learn to live with it. |
| There are none. |
