i am remodeling a kitchen that never had a dishwasher and one will be installed. so i need to run supply and waste lines. what size should the hot water supply line be? what type of fitting should be on the end of the supply line? where should it be located, front or back? what about a waste line? doesn't it just drain into the garbage disposal? thanks for you
