| Posted by hj on March 17, 1999 at 08:42:44: | |
| In response to Re: replacing sewer lines with pvc | |
You cannot, nor would you want to do it. You have to cut the pipe about 2'3 inches from the bell and use a Fernco, no-hub, or similar transition coupling to connect the PVC. : I am moving the toilet across the room and need to change the sewer line. The house is about 60 years old, so has the old cast(?) pipes with lead around the joints. How can I separate the joint and connect PVC pipe to the cast bell?
